Ir para o conteúdo principal
Xiaomi Air 12 SSD Replacement
O que você precisa
  1. Xiaomi Air 12 SSD Replacement, Rear Casing: passo 1, imagem 1 %32
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 SSD Replacement: passo 2, imagem 1 %32 Xiaomi Air 12 SSD Replacement: passo 2, imagem 2 %32 Xiaomi Air 12 SSD Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 SSD Replacement: passo 3, imagem 1 %32 Xiaomi Air 12 SSD Replacement: passo 3, imagem 2 %32
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 SSD Replacement: passo 4, imagem 1 %32 Xiaomi Air 12 SSD Replacement: passo 4, imagem 2 %32 Xiaomi Air 12 SSD Replacement: passo 4, imagem 3 %32
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 SSD Replacement: passo 5, imagem 1 %32 Xiaomi Air 12 SSD Replacement: passo 5, imagem 2 %32
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 SSD Replacement, SSD: passo 6, imagem 1 %32 Xiaomi Air 12 SSD Replacement, SSD: passo 6, imagem 2 %32
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 SSD Replacement: passo 7, imagem 1 %32 Xiaomi Air 12 SSD Replacement: passo 7, imagem 2 %32
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 SSD Replacement: passo 8, imagem 1 %32 Xiaomi Air 12 SSD Replacement: passo 8, imagem 2 %32
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
Conclusão
Hannah Kwan
Membro desde: 04/18/18
839 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G4, Livingston Spring 2018 Membro de Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
Membros da 4
Autoria de 20 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 52
Duração total: 4,212
