Introdução
Teaching you how to replace a crack screen.
O que você precisa
Remove the two bottom screws.
The two bottom screws have a 2.44mm wide tops and are 5.44mm.
Next, work on disconnecting the ribbon for the touch screen.
The touch screen ribbon is larger than the camera ribbon and is located on the left side of motherboard.
Using the spudger, gently pry the ribbon out from under the bar. Pull the ribbon and disconnect it from the motherboard.
Uma outra pessoa concluiu este guia.
