Ir para o conteúdo principal
Xelio P1001A-BK Rear Camera Replacement
O que você precisa
  1. Xelio P1001A-BK Rear Camera Replacement, Back Cover: passo 1, imagem 1 %32 Xelio P1001A-BK Rear Camera Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Rear Camera Replacement: passo 2, imagem 1 %32 Xelio P1001A-BK Rear Camera Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Rear Camera Replacement, Rear Camera: passo 3, imagem 1 %32
    • Locate ribbon connector, make sure it is secure.
  4. Xelio P1001A-BK Rear Camera Replacement: passo 4, imagem 1 %32
    • With a plastic opening tool, gently pry the camera body from its retaining socket
  5. Xelio P1001A-BK Rear Camera Replacement: passo 5, imagem 1 %32
    • Make sure the camera is unobstructed
  6. Xelio P1001A-BK Rear Camera Replacement: passo 6, imagem 1 %32 Xelio P1001A-BK Rear Camera Replacement: passo 6, imagem 2 %32 Xelio P1001A-BK Rear Camera Replacement: passo 6, imagem 3 %32
    • If there is still no picture, remove the securing tab on the ribbon connector by inserting the plastic opening tool between the tab on the ribbon cable connector body.
    • Slowly twist the opening tool to loosen the tab. Move the screwdriver to different parts of the tab to move it a little bit at a time.
    • Once the tab is loose, remove it then slide the ribbon cable from its connector and remove the camera from the tablet
  7. Xelio P1001A-BK Rear Camera Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • With a microfiber lens cleaning cloth, clean the camera lens
  8. Xelio P1001A-BK Rear Camera Replacement: passo 8, imagem 1 %32 Xelio P1001A-BK Rear Camera Replacement: passo 8, imagem 2 %32 Xelio P1001A-BK Rear Camera Replacement: passo 8, imagem 3 %32
    • To install a new camera, slide the ribbon cable back into its connector
    • Reinstall the ribbon cable securing tab
    • Note the indentation that goes along the edge of the securing tab. It must be facing up to orient the tab correctly
    • Install the camera in its retaining socket
Conclusão
Caleb
Membro desde: 03/11/15
101 Reputação
Autoria de 1 guia
Equipe
Colorado Springs, Team 4-2, Panko Spring 2015 Membro de Colorado Springs, Team 4-2, Panko Spring 2015
UCCS-PANKO-S15S4G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 129
