Ir para o conteúdo principal
Introdução
Use this guide to remove and replace the power supply in an Xbox Series X.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
  1. Xbox Series X Power Supply Replacement, Uncover the back panel screws: passo 1, imagem 1 %32 Xbox Series X Power Supply Replacement, Uncover the back panel screws: passo 1, imagem 2 %32
    • Before starting this guide, power down your console and unplug all cables.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Power Supply Replacement: passo 2, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 2, imagem 2 %32 Xbox Series X Power Supply Replacement: passo 2, imagem 3 %32
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers—but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    • Use a T8 Torx driver to remove the two 7.4 mm screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  3. Xbox Series X Power Supply Replacement, Unclip the back panel: passo 4, imagem 1 %32 Xbox Series X Power Supply Replacement, Unclip the back panel: passo 4, imagem 2 %32 Xbox Series X Power Supply Replacement, Unclip the back panel: passo 4, imagem 3 %32
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pivot the spudger on the shell and pull up on the bottom of the back panel to release it from the locking clips.
  4. Xbox Series X Power Supply Replacement: passo 5, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 5, imagem 2 %32
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  5. Xbox Series X Power Supply Replacement, Remove the back panel: passo 6, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the back panel: passo 6, imagem 2 %32 Xbox Series X Power Supply Replacement, Remove the back panel: passo 6, imagem 3 %32
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  6. Xbox Series X Power Supply Replacement: passo 7, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 7, imagem 2 %32 Xbox Series X Power Supply Replacement: passo 7, imagem 3 %32
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  7. Xbox Series X Power Supply Replacement, Remove the fan screws: passo 8, imagem 1 %32
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm wide-head screw
    • Two 8.8 mm screws
    are there any 10.5mm wide head screw for the xbox fan for sale because i need a replacement because i accidentally broke mine
    GhostMindX9 - Responder
  8. Xbox Series X Power Supply Replacement, Disconnect the fan cable: passo 9, imagem 1 %32 Xbox Series X Power Supply Replacement, Disconnect the fan cable: passo 9, imagem 2 %32
    • Use a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  9. Xbox Series X Power Supply Replacement, Remove the fan: passo 10, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the fan: passo 10, imagem 2 %32
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you are replacing the fan, a new fan will probably not include the plastic installation bracket. The bracket is attached to the fan with 4 T10 Torx screws. This is not pictured in this guide.
  10. Xbox Series X Power Supply Replacement, Unlatch the base: passo 11, imagem 1 %32 Xbox Series X Power Supply Replacement, Unlatch the base: passo 11, imagem 2 %32 Xbox Series X Power Supply Replacement, Unlatch the base: passo 11, imagem 3 %32
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  11. Xbox Series X Power Supply Replacement, Twist and remove the base: passo 12, imagem 1 %32 Xbox Series X Power Supply Replacement, Twist and remove the base: passo 12, imagem 2 %32 Xbox Series X Power Supply Replacement, Twist and remove the base: passo 12, imagem 3 %32
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  12. Xbox Series X Power Supply Replacement, Remove the optical drive screws: passo 13, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the optical drive screws: passo 13, imagem 2 %32
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  13. Xbox Series X Power Supply Replacement, Remove the vibration isolator: passo 14, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the vibration isolator: passo 14, imagem 2 %32 Xbox Series X Power Supply Replacement, Remove the vibration isolator: passo 14, imagem 3 %32
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  14. Xbox Series X Power Supply Replacement, Disconnect the power and data cables: passo 15, imagem 1 %32 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: passo 15, imagem 2 %32 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: passo 15, imagem 3 %32
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  15. Xbox Series X Power Supply Replacement, Remove the optical drive: passo 16, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the optical drive: passo 16, imagem 2 %32
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  16. Xbox Series X Power Supply Replacement, Disconnect the USB port cable: passo 17, imagem 1 %32 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: passo 17, imagem 2 %32 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: passo 17, imagem 3 %32
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  17. Xbox Series X Power Supply Replacement: passo 18, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 18, imagem 2 %32
    • Use a pair of tweezers to pull up on the black plastic pull tab to remove the USB port cable from the center chassis.
    • Pull only on the pull tab, not the cable itself.
    Connector i-pex Evaflex 5-HD 24 pin
    20952-024e-02
    http://www.i-pex.com/sites/default/files...
    drops206 - Responder
  18. Xbox Series X Power Supply Replacement, Disconnect the power button cable: passo 19, imagem 1 %32 Xbox Series X Power Supply Replacement, Disconnect the power button cable: passo 19, imagem 2 %32 Xbox Series X Power Supply Replacement, Disconnect the power button cable: passo 19, imagem 3 %32
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
    I broke this connector during disassembly. Is there a part number I can use to get a replacement on Mouser or Digikey?
    Peter LeCraw - Responder
    I broke this connector during disassembly too. Where can I get this connector?
    Oscar Cedeño - Responder
    the manufacturer of connectors in series x is I-PEX.  exact part number (as far as I'm not mistaken) 20535-010E-02 EVAFLEX 5-VS.  0.5mm pin spacing (10pin connector). a possible rescue may be to desolder the connector from the switch board and solder it permanently there.
    How do I purchase this from their website?
    munirbisharat12 -
    I have these connectors. Baycroc@fedtel.net
    Evenson Electronics - Responder
    Would we be able to order them from you directly
    bailey jackson -
    Yes would we be able to order these connectors directly from you?
    Blake Roan -
  19. Xbox Series X Power Supply Replacement, Remove the chassis screws: passo 20, imagem 1 %32
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  20. Xbox Series X Power Supply Replacement, Peel up the USB port cable: passo 21, imagem 1 %32 Xbox Series X Power Supply Replacement, Peel up the USB port cable: passo 21, imagem 2 %32
    • Gently peel the taped USB port ribbon cable off of the heatsink.
  21. Xbox Series X Power Supply Replacement, Remove the center chassis assembly: passo 22, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: passo 22, imagem 2 %32 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: passo 22, imagem 3 %32
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Lift up the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  22. Xbox Series X Power Supply Replacement, Unlatch the chassis strap: passo 23, imagem 1 %32 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: passo 23, imagem 2 %32 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: passo 23, imagem 3 %32
    • Unlatch the chassis strap from the right side of the power supply.
  23. Xbox Series X Power Supply Replacement: passo 24, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 24, imagem 2 %32 Xbox Series X Power Supply Replacement: passo 24, imagem 3 %32
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  24. Xbox Series X Power Supply Replacement, Remove the power cable port: passo 25, imagem 1 %32
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  25. Xbox Series X Power Supply Replacement: passo 26, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 26, imagem 2 %32
    • Lift the power connector out of its recess in the chassis.
  26. Xbox Series X Power Supply Replacement, De-route the power cables: passo 27, imagem 1 %32 Xbox Series X Power Supply Replacement, De-route the power cables: passo 27, imagem 2 %32
    • Unlatch and open the lid on the power cable's plastic guide.
  27. Xbox Series X Power Supply Replacement: passo 28, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 28, imagem 2 %32
    • Lift the power cable out from underneath the extra section of the cable guide.
  28. Xbox Series X Power Supply Replacement, Remove the corner cover: passo 29, imagem 1 %32
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  29. Xbox Series X Power Supply Replacement: passo 30, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 30, imagem 2 %32
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  30. Xbox Series X Power Supply Replacement, Remove the accessory antenna board: passo 31, imagem 1 %32
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  31. Xbox Series X Power Supply Replacement: passo 32, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 32, imagem 2 %32 Xbox Series X Power Supply Replacement: passo 32, imagem 3 %32
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  32. Xbox Series X Power Supply Replacement, Remove the board shield: passo 33, imagem 1 %32
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  33. Xbox Series X Power Supply Replacement: passo 34, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 34, imagem 2 %32 Xbox Series X Power Supply Replacement: passo 34, imagem 3 %32
    • Lift up the board shield to remove it from the center chassis.
  34. Xbox Series X Power Supply Replacement, Remove the chassis strap: passo 35, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the chassis strap: passo 35, imagem 2 %32 Xbox Series X Power Supply Replacement, Remove the chassis strap: passo 35, imagem 3 %32
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  35. Xbox Series X Power Supply Replacement: passo 36, imagem 1 %32 Xbox Series X Power Supply Replacement: passo 36, imagem 2 %32
    • Remove the chassis strap.
  36. Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: passo 37, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: passo 37, imagem 2 %32 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: passo 37, imagem 3 %32
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
  37. Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: passo 38, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: passo 38, imagem 2 %32 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: passo 38, imagem 3 %32
    • Grip and compress the locking tab on the 2-pin power connector.
  38. Xbox Series X Power Supply Replacement, Open the cable guide: passo 39, imagem 1 %32 Xbox Series X Power Supply Replacement, Open the cable guide: passo 39, imagem 2 %32
    • Open the lid on the power supply's plastic cable guide.
  39. Xbox Series X Power Supply Replacement, Remove the power supply screws: passo 40, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the power supply screws: passo 40, imagem 2 %32
    • Use a T8 Torx driver to remove the four screws securing the power supply around its perimeter:
    • Three 35 mm silver screws
    • One 8.8 mm black screw
  40. Xbox Series X Power Supply Replacement, Remove the power supply: passo 41, imagem 1 %32 Xbox Series X Power Supply Replacement, Remove the power supply: passo 41, imagem 2 %32
    • Remove the power supply.
    Bei meinem Ersatznetz teil musste ich auch die Kunststoff Halterung tauschen, da sonst die Löcher für die Schrauben nicht passten
    Mark Kommnick - Responder
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
4 outras pessoas concluíram este guia.
Carsten Frauenheim
Membro desde: 10/03/2020
78.570 Reputação
330 Guias de autoria
iFixit Membro de iFixit
Community
146 Membros
16.118 Guias de autoria
5 Comments
So, I am a skilled DIYer. I had 1 series x that had no power all the sudden, under warranty, sent back and received a refurb. Then I got a halo infinite edition, it all the sudden wouldn't send video. It would power up but I couldn't boot in safe mode or low res mode. Sent it back, send me a refurb. Now my brothers Xbox did the same thing. It turns on but never boots then shuts off after few minutes. No controller connects either, and can't have the xbox sync with the flash. His is not under warranty so I bought a PSU and replaced, still same thing. Any ideas? Microsoft just sends you a refurb and doesn't tell you what was wrong or else I'd know since it happened to my infinite console.
heavychevy9 - Responder
FYI this guide is amazing! Down to providing the length of screws and circling in photos. A++
Well ladies and gentlemen I did it. Took about an hour and a half, only because I put one of the cables on backwards, otherwise it would have only taken an hour. SHES ALIVE!!!! Thank you so much to the person that created these instructions they were SPOT ON!
CAN I GET A A'MEN!!!
Jake Burton - Responder
It just worked for me too! Took me about 2 hours, but I tend to work on this stuff extra slowly to be careful. Thanks so much!
Jon Aron - Responder
Where did you buy the replacement power supply unit from?
I have a series X and the issue I have is that I get a green screen when I turn off the console after playing for a while. I can’t then turn on the console from my controller, only from the console itself. It is as if the Xbox has crashed when shutting down. This only happens on energy saver power mode, not on standby power mode.
Tom Paur - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 30
Últimos 7 dias: 217
Últimos 30 dias: 1,190
Duração total: 13,117
