Introdução
This guide will explain how to disassemble the Xbox DVD Drive in order to preform repairs or remove a stuck game by manually ejecting the drive.
O que você precisa
Remove the disk drive. It should come right out.
Unplug the ribbon cable and yellow cables from back of disk drive.
Remove 4 PH1 Screws
Once screws are removed, lift the bottom half of the case up and away from the drive.
Flip the drive over and remove the top half of the case.
Gently press back on the ribbon retention tab and pull back on the ribbon cable
Press outwards on the 2 plastic retaining tabs
Gently lift PCB over tabs
Only remove these ribbon cables if you need to remove the entire PCB. These are friction fit ribbon cables. In my case, they have a piece of tape holding the ribbon to the connector
Using your screwdriver, or anything slim enough to fit, gently push the white lever back. Put your object on the right hand side of the lever, slightly pushing right as you push back.
The lens will drop down and your drive door will open about a quarter inch.
Gently pull the tray to its open position. If you have a game stuck in your drive, this would be the ideal time to remove it.
Remove the drive belt and replace it with a new one. Belts approximate location highlighted.
6 outras pessoas concluíram este guia.
3 comentários
What is the easiest way to clean the laser in the original xbox?
Hit it with a can of air duster. If further cleaning is required apply a small amount of rubbing alcohol on a Q-tip and gently clean the lens. I hope this helps.
