Ir para o conteúdo principal
Introdução
In this guide, you will learn how to remove the rumble motors located in the triggers. This task requires you to fully disassemble the triggers on the controller.
  1. Remove the battery pack cover.
    • Remove the battery pack cover.
    • Remove batteries.
  2. We recommend using a nylon spudger for this step. A metal spudger is shown. Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. There is a hidden screw located in the middle of the controller behind the label. Use a screwdriver and punch a hole directly in the center of the label.
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the T8 Security Torx Screwdriver.
  4. Remove the backplate.
    • Remove the backplate.
  5. Remove the faceplate.
    • Remove the faceplate.
  6. You may let the rumble motors hang freely out of their sockets. De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
  7. Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
  8. Firmly grip sides of motherboard near the middle.
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
  9. Remove the yellow tape holding the wires in place on the front of the controller.
    • Remove the yellow tape holding the wires in place on the front of the controller.
  10. Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers.
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
  11. Remove the trigger covers.
    • Remove the trigger covers.
  12. Desolder the wires from the motherboard.
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
Conclusão
16 outras pessoas concluíram este guia.
Tommy
Membro desde: 22/01/2015
1.675 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
47 Guias de autoria
9 comentários
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
solofrom303 - Responder
My right trigger won't work on gta 5 and on other games it works
Devean Velasquez - Responder
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow -
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Anthony Bembenek - Responder
Do you know how to remove the plastic plate where the trigger rumble sits?
Angel Marban - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 72
Últimos 30 dias: 353
Duração total: 47,229
