Ir para o conteúdo principal
Introdução
In this guide, you will learn how to remove the rumble motors located in the triggers. This task requires you to fully disassemble the triggers on the controller.
  1. Remove the battery pack cover.
    • Remove the battery pack cover.
    • Remove batteries.
  2. We recommend using a nylon spudger for this step. A metal spudger is shown. Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Start prying the side plate off underneath the trigger, this makes it easier to disconnect the other clips connecting the side plate to the backplate.
    Brandon - Responder
    One you take it off, is it possible to click it back in?
    Aiden Bear - Responder
    As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
    Brandon -
    I don’t have a squdger
    TimidFerret4982 Gaming - Responder
    getting those handles back on seems impossible, they just dont fit as well, a gap remains even after snapping into place.
    Dont think ill be doing this in the future
    Spoutin Wyze - Responder
    edit: wiggled the bo9ttom middlewith the handles off and somethign finally “clicked” into place for that extra 1/4 mm for the down arrow on my D-Pad to click back up into place!.
  3. There is a hidden screw located in the middle of the controller behind the label. Use a screwdriver and punch a hole directly in the center of the label.
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the T8 Security Torx Screwdriver.
    i damaged my screws. how do i get the screws out?
    tenzin - Responder
    wait. i just watched a video guide on ifixit's youtube channel about damaged screws. i'll try those methods.
    tenzin - Responder
    It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
    David Loper - Responder
    All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
    John Dziedzic - Responder
    Am I doing something wrong because I got the tool it said I needed and got the middle screw out but the others have a bump or something in the center of the screw and it won't fit.
    kolton77 - Responder
    The T8 is only good for the middle screw on my One S controller. The others require something bigger
    Matej Skelo - Responder
    These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
    jhighsmith - Responder
    The driver that iFixIt sells is cannulated.
    jhighsmith -
    where do you get this dumb ass screw driver
    Jake Zweier - Responder
    iFixit Store #IF145-027-3
    VauWeh - Responder
    You can bypass it with a 1.5mm flathead.
    Marianne Sandling - Responder
    thank you for this. worked for me
    Mr Anderson (Evolluisionist) -
    These screws required a T10, not T8.
    Armand - Responder
    TR9. A $10 kit from Walmart has the bit/driver in it and extra goodies to make life simple.
    Matt Martin - Responder
    As weird as it sounds, the top 2 came out for me with a flathead- but the bottom two and the middle one wont
    macybrooksevans - Responder
    If you damage the middle part of the screws you can still take it out with the same screwdriver.
    Kev God - Responder
    Thank-You :)
    Isaiah - Responder
    needed a T8H, not easy to see.
    on a grey green xbox one controller
    Michael - Responder
    You need a T8 and the kit is not $10 it’s $13.88 Hyper Tough Electronic Kit. In the hardware section at WalMart it a T8 because I tried everything and only a T8 fit it like a magnet. And the dumbass that wrote the article there is only 1 freaking screw.
    Bear Darazs - Responder
  4. Remove the backplate.
    • Remove the backplate.
  5. Remove the faceplate.
    • Remove the faceplate.
  6. You may let the rumble motors hang freely out of their sockets. De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    Steps 6-8 aren't completely necessary, and are very risky if you aren't good at soldering. It would seem the only reason to remove the motherboard and mess with all this soldering is just so you can reach both screws on the trigger in step 10. However, you can reach them already with a small-bodied screwdriver. Although you might have to rest the screwdriver on the black square processor to reach the bottom screw, it shouldn't damage the processor or motherboard to jimmy that screw out.
    Robert Rapier - Responder
    like mentioned by ‘Robert Rapier’ you can skip the de-soldering in most cases,
    for example cleaning or changing the buttons is doable, but the grey and black wires are pretty short
    and wired through the inner case so it can get a bit fiddly and you have to be careful not to damage them in the process.
    If you have a soldering station around i would still recommend using it.
    yKekS Yzz - Responder
  7. Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    Are these just T6 screws or Torx security T6 that is cannulated?
    Kenan Vickstrom - Responder
    The outer screws are security screws. The ones on the system boards are Torx.
    Rongwey -
  8. Firmly grip sides of motherboard near the middle.
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
  9. Remove the yellow tape holding the wires in place on the front of the controller.
    • Remove the yellow tape holding the wires in place on the front of the controller.
  10. Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers.
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
  11. Remove the trigger covers.
    • Remove the trigger covers.
  12. Desolder the wires from the motherboard.
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
    Perso après le remontage ça n'a jamais refonctionné ma manette détecte plus du tout les gachettes et jai changé les joysticks en même temps et eux non plus ne detecte plus….
    Tuto Free - Responder
Conclusão
16 outras pessoas concluíram este guia.
Tommy
Membro desde: 22/01/2015
1.705 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
47 Guias de autoria
9 comentários
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
solofrom303 - Responder
My right trigger won't work on gta 5 and on other games it works
Devean Velasquez - Responder
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow -
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Anthony Bembenek - Responder
Do you know how to remove the plastic plate where the trigger rumble sits?
Angel Marban - Responder
Could you not just pull the wires?
Spencer Alty - Responder
How do you place the wires back onto the trigger rumble?
Timmy Sparkles - Responder
Where would one buy the replacement trigger motors?
Jared Thicc - Responder
Both wires fell out of one of the motors. How would I be able to fix this?
Abler e - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 87
Últimos 30 dias: 466
Duração total: 48,721
