Ir para o conteúdo principal
Xbox One Wireless Controller Model 1708 Trigger Caps Replacement
O que você precisa
  1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: passo 1, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: passo 1, imagem 2 %32
    • Slide the battery cover out and remove it.
    • Remove the battery pack.
  2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 2, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 2, imagem 2 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool between the handle and the plate.
    • Gently slide the opening tool from the top end to the bottom end of the seam to remove the plate from the handle.
    • Repeat the process with the other side plate.
    • The plate is tightly sealed on the handle, so it may be difficult to remove.
  3. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 3, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 3, imagem 2 %32
    • Remove the five 2.3mm screws on the bottom plate with a T8 Torx security Screwdriver.
    • If there is a sticker on the back, poke a hole with the screwdriver to get to the fifth screw.
  4. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 4, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 4, imagem 2 %32
    • Remove the bottom plate.
  5. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 5, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 5, imagem 2 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 5, imagem 3 %32
    • Carefully turn over the controller with the front plate facing you.
    • Remove the front plate.
  6. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 6, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 6, imagem 2 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 6, imagem 3 %32
    • Remove the two 1.7mm screws from each of the triggers with a T6 Torx screwdriver.
    • It is best to do one trigger cap replacement at a time.
  7. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 7, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 7, imagem 2 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 7, imagem 3 %32
    • Be careful not to let the trigger motor inside come out.
    • Lift the trigger cap off the trigger motor.
  8. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 8, imagem 1 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 8, imagem 2 %32 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: passo 8, imagem 3 %32
    • Place the new trigger cap on the trigger motor.
    • Push down the inside of the trigger cap until you hear a click.
    • Repeat step six to eight for the other trigger cap.
Conclusão
To reassemble your device, follow steps 1-5 in reverse order.
19 outras pessoas executaram este guia.
Equipe
UC Davis, Team S1-G6, Andersen Winter 2020 Membro de UC Davis, Team S1-G6, Andersen Winter 2020
UCD-ANDERSEN-W20S1G6
3 Membros
Autoria de 4 guias
1Comentário do guia
Et le reboitage stp non parce que je pense que ses le plus compliqué.
Yoann.cadenat - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 74
Últimos 30 dias: 380
Ao todo: 24,258
