Ir para o conteúdo principal
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
O que você precisa
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: passo 1, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: passo 1, imagem 2 %32
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 2, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 2, imagem 2 %32
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Only use a pry tool! The vibration motor wires are exposed and directly accessible from the side when opening. I attempted to open it with a small knife, expecting to be able to gently pry the clips open, accidentally sliced through my right motor’s wires.
    Sawyer Coe - Responder
    Not a sharp of course.
    kajussls121 -
    If you have some Guitar picks laying around they work GREAT!
    Mike Beane - Responder
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 3, imagem 1 %32
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Torx-8 security bits work as well.
    jahiamir - Responder
    Torx 8 or 9 wasn’t working. I used 2.0 minus screwdriver
    richjlee - Responder
    The 2.0 minus worked for me as well.
    metric - Responder
    When sliding in the plastic cover during reassembly be sure it lines up with the battery compartment contacts. It can be really easy to not see it and bend the contacts. If you still encounter force during this step, depressing the triggers out of the way worked for me.
    Drew - Responder
    Since mine is out of warranty I just broke out the security nib with a 2.0 standard bit. Then used a T8 torx.
    Tim LaCrosse - Responder
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 4, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 4, imagem 2 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 4, imagem 3 %32
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 5, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 5, imagem 2 %32
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 6, imagem 1 %32
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Reassembly: When placing the back cover on: notice that the battery terminals need to slide inside the cover first. Then compress the triggers slightly, Then the cover will be aligned correctly. Then add the front cover and add screws so it doesn’t come undone.
    hunteil - Responder
    It isn't necessary to take off the back cover
    Otto Hahn - Responder
Conclusão
49 outras pessoas executaram este guia.
Weston Gilmore
Membro desde: 09/25/17
1.789 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G3, Forte Fall 2017 Membro de Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
Membros da 4
Autoria de 32 guias
4 comentários
i used a t8 and it worked
Rudy Bp - Responder
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - Responder
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - Responder
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 61
Últimos 30 dias: 294
Duração total: 24,285
