Ir para o conteúdo principal
Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement
O que você precisa
  1. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement, Bumper: passo 1, imagem 1 %32
    • Remove the battery cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 2, imagem 1 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 2, imagem 2 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 2, imagem 3 %32
    • Grip the controller firmly to remove the side handle cover.
    • Use a flathead screwdriver or a spudger to wedge between the seams of the front to the side handle of the controller.
    • Move the flathead screwdriver all the way around the side plates seam and push the plate forward.
  3. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 3, imagem 1 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 3, imagem 2 %32
    • Use a screwdriver and punch a hole directly in the center label. There you will find a hidden screw.
    • Remove the five 10mm screws located on the back of the controller using a T8 screwdriver.
  4. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 4, imagem 1 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 4, imagem 2 %32
    • Remove the backplate.
    Comment je galère de ouf pour remettre la coque arrière. J'arrive plus aligner la prise Jack ?
    nawack de Marseille - Responder
  5. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 5, imagem 1 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 5, imagem 2 %32
    • Remove the faceplate.
  6. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 6, imagem 1 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 6, imagem 2 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 6, imagem 3 %32
    • Remove the cover piece surrounding the Xbox button off of its pegs.
    • Firmly hold controller and push cover piece up from the pegs.
    • Press the Xbox button down to assist in the unclipping of the piece.
  7. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 7, imagem 1 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 7, imagem 2 %32
    • Remove the broken bumper by unclipping it from its pegs.
    • Hold the controller firmly and push the bumper piece up from its pegs to unclip.
  8. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 8, imagem 1 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 8, imagem 2 %32 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: passo 8, imagem 3 %32
    • Align the replacement bumper onto the pegs, push gently and click into place.
Conclusão
19 outras pessoas executaram este guia.
2 comentários
On my controller the screws were T8 security type, so you'll need bits with a hole in the middle
Sean H - Responder
Is there a way to do this without removing all of the front and grip.
Alan Marantos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 22
Últimos 7 dias: 152
Últimos 30 dias: 669
Duração total: 47,056
