Ir para o conteúdo principal
Xbox One Wireless Controller Faceplate Replacement
O que você precisa
  1. Xbox One Wireless Controller Faceplate Replacement, Battery Pack: passo 1, imagem 1 %32
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Faceplate Replacement, Side Handles: passo 2, imagem 1 %32 Xbox One Wireless Controller Faceplate Replacement, Side Handles: passo 2, imagem 2 %32
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. Xbox One Wireless Controller Faceplate Replacement, Screws: passo 3, imagem 1 %32 Xbox One Wireless Controller Faceplate Replacement, Screws: passo 3, imagem 2 %32
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
  4. Xbox One Wireless Controller Faceplate Replacement, Backplate: passo 4, imagem 1 %32
    • Remove the backplate.
  5. Xbox One Wireless Controller Faceplate Replacement, Faceplate: passo 5, imagem 1 %32
    • Remove the faceplate.
Conclusão
90 outras pessoas executaram este guia.
Tommy
Membro desde: 01/22/15
1.999 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
Autoria de 54 guias
11Comentários do guia
It was a good tutorial, but i have two plastic rings that stay after my instervention... Anyone knows where are-they ?
Matis Begot - Responder Compartilhar
laurito andrea12 - Compartilhar
Note before starting. You need a T8 security bit (with a hole in the middle), not a standard T8 bit.
Fraser Currie - Responder Compartilhar
I took mine a part because it was looking dirty, gave it a good clean, putting it back together was easy but it wont work with the batteries anymore just the power core, there is nothing broken or cracked, any ideas?
Lee - Responder Compartilhar
Maybe you forced the battery contact on the wrong side of the case?
Alexandre Foley - Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 44
Últimos 30 dias: 298
Ao todo: 250,958
