Ir para o conteúdo principal
Xbox One Wireless Controller D-Pad Replacement
O que você precisa
  1. Xbox One Wireless Controller D-Pad Replacement, Battery Pack: passo 1, imagem 1 %32
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller D-Pad Replacement, Side Handles: passo 2, imagem 1 %32 Xbox One Wireless Controller D-Pad Replacement, Side Handles: passo 2, imagem 2 %32
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. Xbox One Wireless Controller D-Pad Replacement, Screws: passo 3, imagem 1 %32 Xbox One Wireless Controller D-Pad Replacement, Screws: passo 3, imagem 2 %32
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
  4. Xbox One Wireless Controller D-Pad Replacement, Backplate: passo 4, imagem 1 %32
    • Remove the backplate.
  5. Xbox One Wireless Controller D-Pad Replacement, Faceplate: passo 5, imagem 1 %32
    • Remove the faceplate.
  6. Xbox One Wireless Controller D-Pad Replacement, Metal Frame: passo 6, imagem 1 %32 Xbox One Wireless Controller D-Pad Replacement, Metal Frame: passo 6, imagem 2 %32
    • Pry off the metal frame around the D-Pad.
  7. Xbox One Wireless Controller D-Pad Replacement, D-Pad: passo 7, imagem 1 %32
    • Lift the D-Pad out of its housing.
Conclusão
49 outras pessoas executaram este guia.
Garrett George
Membro desde: 01/22/15
6.429 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
Autoria de 54 guias
7Comentários do guia
Can you show me how to replace xbox one controller 3.5mm stereo jack dpad
Arief Hidayat - Responder
This model of the xbox one controller does not feature a 3.5mm headphone jack. Please look at the guides for later models of the xbox one controller.
Brandon -
it's exactly the same like shown above :)
David Schmidt - Responder
How do u fix one of the silver things behind the d-pad?
Bob - Responder
How do fix the silver things behind each d-pad
Bob - Responder
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 79
Últimos 30 dias: 444
Ao todo: 70,176
