Ir para o conteúdo principal
Xbox One Wireless Controller 1697 Thumbstick Replacement
O que você precisa
  1. Xbox One Wireless Controller 1697 Thumbstick  Replacement, Thumbstick: passo 1, imagem 1 %32
    • Slide the battery pack cover toward the top of the controller to remove it.
    • Remove batteries.
  2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 2, imagem 1 %32 Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 2, imagem 2 %32
    • We recommend using a plastic spudger to prevent damage to your controller. However, using a metal spudger, as shown in the picture, makes the work easier.
    • Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
    • Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
    • Repeat this process for both side handles.
  3. Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 3, imagem 1 %32 Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 3, imagem 2 %32
    • Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label.
    • You can punch a hole using a screwdriver or peel off the label.
  4. Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 4, imagem 1 %32 Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 4, imagem 2 %32 Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 4, imagem 3 %32
    • Remove the back plate.
  5. Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 5, imagem 1 %32
    • Remove the faceplate
  6. Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 6, imagem 1 %32 Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 6, imagem 2 %32 Xbox One Wireless Controller 1697 Thumbstick  Replacement: passo 6, imagem 3 %32
    • Select the thumbstick that you want to replace and pull it off its pole.
Conclusão
28 outras pessoas executaram este guia.
Emely
Membro desde: 09/27/17
866 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S9-G1, Remmell Fall 2017 Membro de USF Tampa, Team S9-G1, Remmell Fall 2017
USFT-REMMELL-F17S9G1
4 Membros
Autoria de 14 guias
1Comentário do guia
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
Isak - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 37
Últimos 30 dias: 206
Ao todo: 26,247
