Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Firmly grip the ear pad and the plastic back plate underneath. With your other hand, grip the back of the speaker casing.
With the ear pad facing you, push down on the back plate and turn counter-clockwise to unlock the prongs holding it in place. The back plate will only rotate about 1 cm.
Lift the back plate (with the ear pad attached) straight up from the speaker.
Remove three 7 mm Phillips #00 screws holding the speaker in place.
Carefully open the back casing, exposing the speaker wires.
Use wire cutters to cut the blue and black wires from the headset close to where they are spliced to the red and black wires from the speaker.
Splice the headset wires to the corresponding replacement speaker wires.
12 outras pessoas executaram este guia.
3 comentários
what part is using to hold the speaker in place that you can adjust to fit your head
where can I buy the replacement speaker ?
Can some help me with fixing a earmuff detached from the head band but the wires are still attached
