Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
If either speaker in the headset stops playing sound, is much quieter than the other, or produces hissing and crackling noises, then it may be damaged or broken. Removing the broken speaker is fairly simple.
Installing a replacement, however, will require knowing how to splice wires together. Wire splicing requires wire strippers, soldering tools, and either heat shrink tubing or electrical tape. This guide will show you how to remove the existing speaker and indicate which wires need to be spliced.
  1. Firmly grip the ear pad and the plastic back plate underneath. With your other hand, grip the back of the speaker casing.
    • Firmly grip the ear pad and the plastic back plate underneath. With your other hand, grip the back of the speaker casing.
    • Do not grip the back of the speaker by the headband. Twisting this connection will break the headphone off the headband.
    • With the ear pad facing you, push down on the back plate and turn counter-clockwise to unlock the prongs holding it in place. The back plate will only rotate about 1 cm.
  2. Lift the back plate (with the ear pad attached) straight up from the speaker.
    • Lift the back plate (with the ear pad attached) straight up from the speaker.
    • This should be very easy to do. If it doesn't come off easily, then the plate isn't fully rotated.
  3. Remove three 7 mm Phillips #00 screws holding the speaker in place.
    • Remove three 7 mm Phillips #00 screws holding the speaker in place.
  4. Carefully open the back casing, exposing the speaker wires.
    • Carefully open the back casing, exposing the speaker wires.
  5. Use wire cutters to cut the blue and black wires from the headset close to where they are spliced to the red and black wires from the speaker.
    • Use wire cutters to cut the blue and black wires from the headset close to where they are spliced to the red and black wires from the speaker.
    • Splice the headset wires to the corresponding replacement speaker wires.
    • Black connects to black, red connects to blue.
    • Although soldering isn't necessary when splicing wires, doing so creates a more reliable connection.
Conclusão
10 outras pessoas concluíram este guia.
Shannon Prouty
Membro desde: 30/01/2015
715 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-37, Amido Winter 2015 Membro de Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 Membros
5 Guias de autoria
what part is using to hold the speaker in place that you can adjust to fit your head
Nicholas Ryver - Responder
where can I buy the replacement speaker ?
Juan Carlos Sánchez Pulido - Responder
Can some help me with fixing a earmuff detached from the head band but the wires are still attached
Harry Obrastsoff-Rutinsky - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 44
Duração total: 11,013
