Ir para o conteúdo principal
Xbox One Stereo Headset Microphone Replacement
O que você precisa
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, imagem 1 %32 Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, imagem 2 %32 Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, imagem 3 %32
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: passo 2, imagem 1 %32
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: passo 3, imagem 1 %32
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: passo 4, imagem 1 %32 Xbox One Stereo Headset Microphone Replacement: passo 4, imagem 2 %32 Xbox One Stereo Headset Microphone Replacement: passo 4, imagem 3 %32
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: passo 5, imagem 1 %32
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: passo 6, imagem 1 %32
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
Conclusão
4 outras pessoas executaram este guia.
Trevor Steele
Membro desde: 02/01/15
233 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-37, Amido Winter 2015 Membro de Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
Membros da 4
Autoria de 5 guias
9 comentários
Is a replacement microphone available from iFixit?
Scott Minton - Responder
What do you replace the mic with?
Its Me - Responder
They have the microphone for sale
daniel david guerrerogarcia - Responder
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Responder
Any mod to make the cable removable?
kikis.andcream - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 23,822
