Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert the metal spudger between the foam ear pad and the black plastic speaker cover.
Carefully slide the spudger between the ear pad and the speaker cover, along the seam, to remove the adhesive.
Using your fingers, carefully pull the ear pad out from the black cloth cover.
3 comentários
There is actually a much easier way to do this. Hold the ear cup in one hand with the plastic side down. Use your other hand to turn the pad counter clockwise until you hear a click. It should move no more than 1/4 of an inch. Now the two parts are separated and you will have access to the back of the large pad to replace the inner one.
