Ir para o conteúdo principal
Xbox One Stereo Headset Foam Ear Pads Replacement
O que você precisa
  1. Xbox One Stereo Headset Foam Ear Pads Replacement, Foam Ear Pads: passo 1, imagem 1 %32 Xbox One Stereo Headset Foam Ear Pads Replacement, Foam Ear Pads: passo 1, imagem 2 %32
    • Insert the metal spudger between the foam ear pad and the black plastic speaker cover.
  2. Xbox One Stereo Headset Foam Ear Pads Replacement: passo 2, imagem 1 %32
    • Carefully slide the spudger between the ear pad and the speaker cover, along the seam, to remove the adhesive.
  3. Xbox One Stereo Headset Foam Ear Pads Replacement: passo 3, imagem 1 %32 Xbox One Stereo Headset Foam Ear Pads Replacement: passo 3, imagem 2 %32
    • Be careful not to tear the cloth ear pad cover.
    • Using your fingers, carefully pull the ear pad out from the black cloth cover.
    • When reinserting the foam ear pad, you may want to use a foam-safe adhesive to secure the back side of the foam to the plastic speaker cover.
Conclusão
Thor Watsjold
Membro desde: 01/30/15
188 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-37, Amido Winter 2015 Membro de Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
Membros da 4
Autoria de 5 guias
3 comentários
How do I glue/stick it back? =(
Dannylo - Responder
There is actually a much easier way to do this. Hold the ear cup in one hand with the plastic side down. Use your other hand to turn the pad counter clockwise until you hear a click. It should move no more than 1/4 of an inch. Now the two parts are separated and you will have access to the back of the large pad to replace the inner one.
therundi - Responder
Thanks therundi!
aesgene - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 8,504
