Ir para o conteúdo principal
Xbox One S Power Block Replacement
O que você precisa
  1. Xbox One S Power Block Replacement, Case: passo 1, imagem 1 %32
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Power Block Replacement: passo 2, imagem 1 %32
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    Be careful not to damage the pairing button on this part
    David - Responder
    Important!!
    You've to start from the back corner where is the information label, because there is a main clip behind a warranty sticker
    Cristian Ramirez - Responder
    They should add this to the guide! I didnt know that, and did some minor damage to the bottom piece where that main clip is.
    I dont mind because it's my own Xbox, but what if it belonged to a customer?
    Charles Jackson -
    💯% same opinion!
    profnussecke42o -
    This was hard! I tried using plastic pry tools, but they did not work. A metal tool did, but make sure to watch a video or two, to see what you actually are dealing with. After the videos it went quite smoothly.
    Peterdk - Responder
    I legitimately cannot open the case where the warranty sticker is, ive tried everything, im resorting to a fork to try and open this
    Sohail ツShah - Responder
  3. Xbox One S Power Block Replacement: passo 3, imagem 1 %32
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Power Block Replacement: passo 4, imagem 1 %32 Xbox One S Power Block Replacement: passo 4, imagem 2 %32
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    My F3 isn't coming out. The screwdriver isn't sitting tight like it is for the other ones. Any idea on how to fix that?
    ben mccord - Responder
  5. Xbox One S Power Block Replacement: passo 5, imagem 1 %32 Xbox One S Power Block Replacement: passo 5, imagem 2 %32
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield
    Essential tip: be sure to slide the metal housing backward, away from the from of the case as pictured above, rather than upward. If not, you can easily break off the teeny momentary switches on the IR blaster board!
    Mark Ross - Responder
    “appropriate method is not descriptive like Mr. Ross’s comment. The original poster should edit the description to ensure people do in fact remove the box from the case appropriately. I would also add arrows to the picture.
    Ryan A - Responder
    ____________⬆️
    ↖️Yes! I see it the same way!↗️
    ⬅️Arrows are always a good thing!➡️
    ↙️Can't do anything wrong with them! ↘️
    ____________⬇️
    profnussecke42o -
    I didn't realize that metal ribbon was connecting the case to the console and I yanked it w out realizing it was there. How o I get a replacement?
    Jerianna Mike - Responder
  6. Xbox One S Power Block Replacement, Hard Drive Assembly: passo 6, imagem 1 %32 Xbox One S Power Block Replacement, Hard Drive Assembly: passo 6, imagem 2 %32
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
    Some of my silver were gold screws, so just letting people know to look out for that!
    jovialkitten - Responder
    The Torx screw circled on the left is actually C5
    Jaryn Wickman - Responder
    I found the same. On my Xbox One S, it's C3 and C5 that hold in the hard drive caddy. C4 holds in the optical disk caddy.
    jamesr -
    Yeah, C3 and C5 on my console too.
    Jahn Roux - Responder
    Funny thing on my console rev t t3 built feb 2018 it’s C4 and C5
    KingofRome - Responder
    The instructions fail to mention that the top metal cover can be lifted off at this point without undoing any more screws.
    CityZ - Responder
  7. Xbox One S Power Block Replacement: passo 7, imagem 1 %32 Xbox One S Power Block Replacement: passo 7, imagem 2 %32 Xbox One S Power Block Replacement: passo 7, imagem 3 %32
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    Do not disconnect the connector in the second image! There are tiny prongs that bend easily and if bent just a tad bit they will break off. I had first hand experience with this and I ended up breaking my Xbox because I could not put that cable back on.
    [deleted] - Responder
    Do not remove the cable!!!! You can change while the cables are plugged. It took 2 hours trying to put mm precisely all the little pins because of the removal of the cables.
    Please update the post, I could easily end up as the Aaron, breaking the XBOX completly.
    Botond Kopacz - Responder
    Yes, this has also happened to me the connectors had broken and the pins bent and snapped off.
    Samuel Garbutt - Responder
  8. Xbox One S Power Block Replacement, Optical Drive Assembly: passo 8, imagem 1 %32
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
    The image shows screw 'C4' witch is the correct screw. 'C5' is for the HDD.
    GoJoel - Responder
  9. Xbox One S Power Block Replacement: passo 9, imagem 1 %32
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
  10. Xbox One S Power Block Replacement, Motherboard: passo 10, imagem 1 %32
    • To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • Remove the four black 8 mm T-8 Torx screws lablelled "A1," "A2," "A3," and "A4."
    The Black screws are T-8 Torx, not T-9!
    Jakub Krzyskow - Responder
    I didnt see this before, so thankfully I was able to use T9 without stripping the screws!
    Charles Jackson -
    IMPORTANT! You also need to remove the two T10 screws labeled B1 and B2 in order to remove the motherboard! I had to figure this out on my own.
    Charles Jackson - Responder
    I hust had to remove the red ones and than i was able to lift the powersupply of the mainboard
    Dennis M - Responder
    I had to remove B1 and B2 as well.
    Seen Bee - Responder
  11. Xbox One S Power Block Replacement: passo 11, imagem 1 %32
    • Locate the rectangular silver clamp on the opposite corner of the power block.
    • Remove the black bracket near the fan.
    Remember to remove the black bracket by the fan!
    Martin Samuelsson - Responder
  12. Xbox One S Power Block Replacement: passo 12, imagem 1 %32
    • Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • It's okay to apply a little bit of force here to get the clamp off the silver casing. The metal is bendable and can be bent/clamped back on.
  13. Xbox One S Power Block Replacement, Remove Wifi antenna: passo 13, imagem 1 %32
    • Remove the four black 8 mm T-9 Torx screws labeled "E1," "E2," "E3," and "E4."
  14. Xbox One S Power Block Replacement, Remove Mediatek board: passo 14, imagem 1 %32
    • Remove the three black 8 mm T-9 Torx screws labeled "D1," "D2," and "D3" to remove the Mediatek board.
    What bit couldninuse tontake D1-3 screws off
    Amanda Zapata - Responder
  15. Xbox One S Power Block Replacement: passo 15, imagem 1 %32
    • Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
    They forget, I think, to tell that first you need to take off screw B1 and B2
    Gabriel Varela - Responder
  16. Xbox One S Power Block Replacement, Power Block: passo 16, imagem 1 %32
    • Gently lift the power block off the motherboard
  17. Xbox One S Power Block Replacement: passo 17, imagem 1 %32
    • Locate the black connector that joins the power block to the motherboard.
    • The protruding rectangular part of the plastic connector, shown by the orange marker, is a locking tab.
  18. Xbox One S Power Block Replacement: passo 18, imagem 1 %32
    • Grab the connector as shown, pinch the small black locking tab, and pull firmly upward to detach the power block from the motherboard .
Conclusão
40 outras pessoas executaram este guia.
Erik Ramazzini
Membro desde: 04/26/17
2.749 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S22-G3, Livingston Spring 2017 Membro de Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
Membros da 4
Autoria de 56 guias
20 comentários
So my Xbox One S isn’t turning on at all. No light, nothing. I went to take it apart and I plugged it in just to see if it would boot out of the blue. I turned it on and nothing happened but I can hear a faint clicking sound from the power supply. Does that mean, the power supply has gone bad, and I’ll need to replace it?
Cyology.IO - Responder
yes because this xbox one s internal power supply is a fail.. look at there newer model the “xbox one x “ the internal powersupply of it has air ventilation coming from the upgraded version of the fan.
meaning the xbox one s power supply has no proper ventilation no air that blow the exhaust the heat will stuck up inside .. thats why it will not last longer .
the worst is that its design it self .. imagine when you accidentaly pour a water into the fan .. the water will go directly to the cpu and mobo.
that is why they upgrade the “xbox one x“ they copied the design from the ps4 that the air ventilation is on the side panels..
Michael Creech - Responder
My xbox one s stopped working after a power surge from a string of storms. It wont respond, make any noise at all. I figured i would replace the power supply and see if that’s the fix. While i’m waiting for the part to arrive, i’m wondering if there is any other damage that could’ve been done by the surge. Or does the power supply prevent that?
quintalnick - Responder
did you ever get that storm Xbox to work? I just lost mine to a storm last night :(
Adam Portugali -
my one s is working fine all apps are good my network connection is goood its cleaned and maintenanced properly all is working well until i try doing the one thing i bought it for playing games doesnt matter if its disc or downloaded soon as it loads and im ready to play the console crashes to no signal and shuts off
spanky8623 - Responder
So I replaced my Xbox's power supply, but it still won't power on… it still as dead as before I did the repair. It was damaged by a power surge I do believe. Could it be the cable? It shows no sign of damage. What else do I do?
Jorge Ambriz - Responder
Change the mosfets
reymen_dvd -
Same thing is happening with mine. Were you able to fix it?
h4rdym4n -
My One S died after a storm, I directly thought about the power block, bought it for nothing on eBay. Just replaced today, problem solved perfectly working !
quentinremy - Responder
So my xbox one s is having the no power to mobo.. But when i take it out and plug it in and use my volt meter it says 12.00 v on more then 4 prongs on the wired end that would plug into the mobo.. So I assume hope not mobo fried but there's no sighn of burning or any other electrical abuse? Any ideas would be great
Jeremi Eaton - Responder
This worked for me! Getting that black case off is difficult but dont be afraid of the noises it makes..you really aren’t completely destroying it, it just sounds like you are.
After taking apart my Xbox one s and replacing its power supply with a new one it still shows no signs of life. Both power supplies show no lights when trying to turn it on, also no sound. Is there any other way I could fix this or can I declare this xbox as being dead?
m.m.afman - Responder
So I followed the guide, replacing the power supply, but I ended up breaking off the power switch from the RF/IR board putting it back together. Have to wait for that part to come now. The guide has the reader remove the optical and hard drives from the device, and loosening the motherboard. To be honest, I found that to be unnecessary, as you can just use a pair of tweezers to pinch the power connector in order to disconnect it from the motherboard. At worst you’ll want to just move the hard drive out of the way to lift the power supply out. By the way, if you are going to loosen the motherboard, you’ll probably need to remove screws B1 and B2 as well as remove the WiFi board and RF/IR board, none of which is mentioned in this guide.
Aaron - Responder
So my Xbox one s will come on for less than five seconds then turn off. I’ve done everything execpt replace the power block. It’s kinda expensive for me and I don’t want to spend 40-60$ Just for it to continue to not work so before I buy it does anyone know if this Actually helps or not?
Maria - Responder
i replaced the power supply in my xboxone s, but it still will not come on
lee_64_99 - Responder
My Xbox got slammed and when I turn it on the fan moves for a second and then immediately stops im hearing its the power supply but im not sure it wasn’t slammed too hard where multiple things would be destroyed
Chrisbee - Responder
My Xbox one s will power on then shut off within couple seconds, idk when it started bc I hadn’t touched it for month maybe and then it started powering off after couple seconds and I’ve cleaned it so idk what it could be
Mike - Responder
My Xbox one s get wet on the top not a lot of water. I took it apart and I couldn't see any on motherboard etc. But.... It won't power on and there is a faint high pitch beeping noise I hear. I checked the power supply with multimeter and it says 11.97 volts what could he the issue
Michelle Bowes - Responder
Every time I play big games like Apex, MW2 or Fortnite, my Xbox one s freezes and shuts off. Could that be the power supply being bad because of the bad ventilation? I can’t play Farming Sim and Roblox just fine, but if I load any of the big games it crashes. I can watch YouTube or HBO and it would work fine. Should I just buy a new power supply and fix it myself or is there another thing to do that would fix the problem, I factory reset it twice to see if that would do anything and I even took the power supply out to see if it was dusty and it was fine but it still freezes.
Just want to know if I should buy a new power supply or not??
Wyatt Mills - Responder
How do you get the internal power supply apart after you get it out of the Xbox? I see one clip. But can't find a second one. no screws I see. just a black mesh and wires. When I unclip the one side it moves but the other side isn't moving. This thing is so dirty blowing it out is not going to get all the dust out. And 2 I want to see if I can repair it before I buy a new one. But don't want to brake it to pieces. Just in case I can repair it.
Bobby Cook - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 97
Últimos 30 dias: 400
Duração total: 75,574
