Introdução
This guide will show you how to remove the top panel of the interior case of the Xbox Box One S. This is necessary for the removal of either the hard drive, the disk drive, the heatsink/fan, the motherboard, or the power block.
O que você precisa
Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
12 outras pessoas executaram este guia.
2Comentários do guia
Pourquoi ma X boxe One s'allume plus
