Ir para o conteúdo principal
Xbox One S IR Blaster and Wireless Controller Replacement
O que você precisa
  1. Xbox One S IR Blaster and Wireless Controller Replacement, Case: passo 1, imagem 1 %32
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S IR Blaster and Wireless Controller Replacement: passo 2, imagem 1 %32
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    Be careful not to damage the pairing button on this part
    David - Responder
    Important!!
    You've to start from the back corner where is the information label, because there is a main clip behind a warranty sticker
    Cristian Ramirez - Responder
    They should add this to the guide! I didnt know that, and did some minor damage to the bottom piece where that main clip is.
    I dont mind because it's my own Xbox, but what if it belonged to a customer?
    Charles Jackson -
    💯% same opinion!
    profnussecke42o -
    This was hard! I tried using plastic pry tools, but they did not work. A metal tool did, but make sure to watch a video or two, to see what you actually are dealing with. After the videos it went quite smoothly.
    Peterdk - Responder
    I legitimately cannot open the case where the warranty sticker is, ive tried everything, im resorting to a fork to try and open this
    Sohail ツShah - Responder
  3. Xbox One S IR Blaster and Wireless Controller Replacement: passo 3, imagem 1 %32
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S IR Blaster and Wireless Controller Replacement: passo 4, imagem 1 %32 Xbox One S IR Blaster and Wireless Controller Replacement: passo 4, imagem 2 %32
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    My F3 isn't coming out. The screwdriver isn't sitting tight like it is for the other ones. Any idea on how to fix that?
    ben mccord - Responder
  5. Xbox One S IR Blaster and Wireless Controller Replacement: passo 5, imagem 1 %32 Xbox One S IR Blaster and Wireless Controller Replacement: passo 5, imagem 2 %32
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield
    Essential tip: be sure to slide the metal housing backward, away from the from of the case as pictured above, rather than upward. If not, you can easily break off the teeny momentary switches on the IR blaster board!
    Mark Ross - Responder
    “appropriate method is not descriptive like Mr. Ross’s comment. The original poster should edit the description to ensure people do in fact remove the box from the case appropriately. I would also add arrows to the picture.
    Ryan A - Responder
    ____________⬆️
    ↖️Yes! I see it the same way!↗️
    ⬅️Arrows are always a good thing!➡️
    ↙️Can't do anything wrong with them! ↘️
    ____________⬇️
    profnussecke42o -
    I didn't realize that metal ribbon was connecting the case to the console and I yanked it w out realizing it was there. How o I get a replacement?
    Jerianna Mike - Responder
  6. Xbox One S IR Blaster and Wireless Controller Replacement, IR Blaster and Controller Wireless Connection: passo 6, imagem 1 %32
    • The IR blaster can be identified on one of the sides of the interior case. It will be next to the disc drive and near the fan.
  7. Xbox One S IR Blaster and Wireless Controller Replacement: passo 7, imagem 1 %32
    • Use a Torx T8 screwdriver to remove the four 15 mm screws with orange circles around them.
    • Gently pull the IR blaster off the case.
Conclusão
15 outras pessoas executaram este guia.
Christopher Chen
Membro desde: 04/26/17
621 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S22-G3, Livingston Spring 2017 Membro de Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
Membros da 4
Autoria de 56 guias
2 comentários
When the board gets replaced does the power light still function normally? I just replaced one because a power button failed and while the new switches work the indicator lights will not power on
Brandon Shrader - Responder
Question. What's size and type of button does this board use? I have one with the eject and sync button sheered off.
Frank urmom - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 40
Duração total: 5,505
