Ir para o conteúdo principal
Xbox One S All Digital Edition Power Supply Replacement
O que você precisa
  1. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: passo 1, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: passo 1, imagem 2 %32 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: passo 1, imagem 3 %32
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Power Supply Replacement: passo 2, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 2, imagem 2 %32
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Power Supply Replacement: passo 3, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 3, imagem 2 %32
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Power Supply Replacement: passo 4, imagem 1 %32
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: passo 5, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: passo 5, imagem 2 %32
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Power Supply Replacement: passo 6, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 6, imagem 2 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 6, imagem 3 %32
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: passo 7, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: passo 7, imagem 2 %32
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  8. Xbox One S All Digital Edition Power Supply Replacement: passo 8, imagem 1 %32
    • Carefully remove the WiFi Card from the metal chassis.
    Hello , I have a question.
    Can I play the xbox one all digital fully offline, without the wi-fi card plugged into it ?
    Il Lupo - Responder
    You should be able to play offline without the card. This is assuming you downloaded whatever games you plan to play before removing the card.
    Sebastian Rosso -
  9. Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: passo 9, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: passo 9, imagem 2 %32
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  10. Xbox One S All Digital Edition Power Supply Replacement: passo 10, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 10, imagem 2 %32
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  11. Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: passo 11, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: passo 11, imagem 2 %32
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Power Supply Replacement: passo 12, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 12, imagem 2 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 12, imagem 3 %32
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Power Supply Replacement: passo 13, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 13, imagem 2 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 13, imagem 3 %32
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: passo 14, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: passo 14, imagem 2 %32 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: passo 14, imagem 3 %32
    • Gently lift the hard drive to free up some space around the power supply.
  15. Xbox One S All Digital Edition Power Supply Replacement: passo 15, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 15, imagem 2 %32
    • Lift the power supply up and away from the motherboard.
  16. Xbox One S All Digital Edition Power Supply Replacement: passo 16, imagem 1 %32 Xbox One S All Digital Edition Power Supply Replacement: passo 16, imagem 2 %32
    • Disconnect the six pin connector from the motherboard.
Conclusão
4 outras pessoas executaram este guia.
Jules Hajjar
Membro desde: 10/10/19
1.531 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team S12-G6, Regan Fall 2019 Membro de Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
Membros da 4
Autoria de 26 guias
3 comentários
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
William Oliver - Responder
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
Jules Hajjar -
replace the PSU and still boots up and shuts off
imafuxer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 31
Últimos 30 dias: 143
Duração total: 6,830
