Introdução
This replacement guide provides a step by step process on replacing the IR Blaster of The Xbox One S All Digital Edition (Model 1681). The IR Blaster is responsible for many of the consoles vital power functions. The IR Blaster contains the consoles power switch and manages the connection of Bluetooth accessories paired to the Xbox One S All Digital Edition. Symptoms of a broken IR Blaster are a malfunctioning power button or a faulty Bluetooth connection to Xbox accessories. Disconnect all cables prior to disassembly.
O que você precisa
Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
Repeat on different points of the plastic enclosure until the bottom cover is removed.
Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
Uma outra pessoa concluiu este guia.
