Introdução
This guide shows the steps necessary to get the motherboard separated from the bottom part of the metal chassis of the Xbox One S All Digital Edition (Model 1681). The chassis might need to be replaced in the console experiences power issues or if the unit has fallen on the ground in the past. Disconnect all cables prior to disassembly.
O que você precisa
Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
Repeat on different points of the plastic enclosure until the bottom cover is removed.
Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
3 outras pessoas executaram este guia.
