Introdução
The optical drive reads game, DVD, BluRay, and music discs. The Optical drive is connected to the motherboard via two colored cables, one that provides power, and one that transmits data.
O que você precisa
Slide the black angled tab behind the silver button toward the back of the console and set it aside.
Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
The optical drive is now free, lift it from the chassis and set it aside.
16 outras pessoas executaram este guia.
7 comentários
Are the drives paired as the 360 ones were do we need to swap over the logic board to get game playback? Thanks
Yes they are married in the same way as the 360 is. It's not difficult at all to swap.
i cant do this im only a kid and my dad will get mad at me if I do this
