Introdução
The infrared camera receives IR signals emitted from the blasters. This permits the Kinect to measure the distance to an object in its vicinity. The IR camera is mounted on the heat sink inside the device.
O que você precisa
Remove the sticker on the underside of the device.
Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
Lift the internal assembly with the spudger.
Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
First step is to make sure that the inner compartment containg the camera is separated from the outer casing.
Um comentário
I have the new Infrared Camera ,1080p HD wide-angle camera,motherboard, IR projectors board.If you need please contact me.
