O que você precisa
Instruções em vídeo
Conclusão
To reassemble your device, follow these instructions:
Últimas 24 horas: 18
Últimos 7 dias: 66
Últimos 30 dias: 314
Ao todo: 9,164
5Comentários do guia
Less than 6 months of having this and the RB has to apply more pressure to work. To fix this I have to solder. I won't buy this controller ever again.
PrivateUser30 - Responder
Me too. It's hard to believe, but it's true: the Elite 2 controller costs many times more than a regular one. However, its quality doesn't justify the price at all. In short: the price is much higher, and the quality is much lower. Shame on you, Microsoft..."
NordKeta - Responder
I keep having issues, I manage to remove the button but there is still solder stuck in the hole so I cannot passthrough a new button... I have used wick, solder pump and reflowing with new solder, nothing works?
Any ideas??
Craig Ireland - Responder
You could try adding more solder and keep it liquid while someone slides the button in from the other side... Not the best idea, but if you're short on options and if it's only one hole having this problem it might work.
Iris -
Hey, use desoldering pump to clean pins. Don’t overheat plate.
Dmytro Mak -
