Ir para o conteúdo principal
Xbox One Elite Controller (Model 1698) Motherboard Replacement
O que você precisa
  1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: passo 1, imagem 1 %32 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: passo 1, imagem 2 %32
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad
  2. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Removing the back panel screws: passo 2, imagem 1 %32
    • Remove the 5 Torx Security Bit (TR9) screws
  3. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: passo 3, imagem 1 %32 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: passo 3, imagem 2 %32 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: passo 3, imagem 3 %32
    • Pry the panel next to the 3.5mm port
    • Be careful to not rip the ribbon shown in the next step
  4. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: passo 4, imagem 1 %32 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: passo 4, imagem 2 %32
    • Be careful to not rip the ribbon cable
    • You can pop the connector up to remove the ribbon easily
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Screws on controller motherboard: passo 5, imagem 1 %32
    • Remove the 2 Torx (T6) screws
  6. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: passo 6, imagem 1 %32 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: passo 6, imagem 2 %32
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT
  7. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: passo 7, imagem 1 %32 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: passo 7, imagem 2 %32
    • Pull up from the "top" side of the controller on the sister board.
Conclusão
9 outras pessoas executaram este guia.
EasyAsABC123
Membro desde: 01/22/10
2.428 Reputação
Autoria de 5 guias
Um comentário
50 minutes? half of that tops
glenn.fowell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 65
Duração total: 16,773
