Ir para o conteúdo principal
Xbox One Elite Controller (Model 1698) Disassembly
O que você precisa
  1. Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: passo 1, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: passo 1, imagem 2 %32
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
  2. Xbox One Elite Controller (Model 1698) Disassembly, Removing the back panel screws: passo 2, imagem 1 %32
    • Remove the 5 Torx Security Bit (TR9) screws.
  3. Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: passo 3, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: passo 3, imagem 2 %32 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: passo 3, imagem 3 %32
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
  4. Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: passo 4, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: passo 4, imagem 2 %32
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Disassembly, Screws on controller motherboard: passo 5, imagem 1 %32
    • Remove the 2 Torx (T6) screws.
  6. Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: passo 6, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: passo 6, imagem 2 %32
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
  7. Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: passo 7, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: passo 7, imagem 2 %32
    • Pull up from the "top" side of the controller on the daughterboard.
  8. Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: passo 8, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: passo 8, imagem 2 %32 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: passo 8, imagem 3 %32
    • Be Careful to not lose the sync button.
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part.
  9. Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: passo 9, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: passo 9, imagem 2 %32
    • Unscrew the 6 Torx (T6) screws.
  10. Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: passo 10, imagem 1 %32 Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: passo 10, imagem 2 %32
    • Now you can remove the buttons themselves.
Conclusão
45 outras pessoas executaram este guia.
EasyAsABC123
Membro desde: 01/22/10
2.557 Reputação
Autoria de 5 guias
14Comentários do guia
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
jones_8515 - Responder Compartilhar
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
J'Anthony Joseph - Responder Compartilhar
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
Craig Amyotte - Responder Compartilhar
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Mat - Responder Compartilhar
Thanks for the info
EasyAsABC123 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 89
Últimos 30 dias: 365
Ao todo: 104,497
