Introdução
This guide will show you how to replace your Xbox's hard drive.
Ferramentas
Peças
Nenhum componente especificado.
52 outras pessoas concluíram este guia.
15 comentários
can you replace the hard drive with one that has windows or linux on it and run windows or linux from the hdd and turn the xbox into a media pc or is the xbox OS not in the hdd but in a chip on the motherboard that cannot be overridden so that it boots from the hdd
NO, you cannot.
kaos_engr is wrong. You CAN run Linux on a modded Xbox. Although since you also asked about REPLACING the hard drive: I don’t know whether you have to use the original hard drive or can use any IDE hard drive. But Linux is apparently possible on a modded Xbox. See here, and there are more resources on the web too, just search the web for “original Xbox linux”: https://en.wikipedia.org/wiki/Xbox_Linux
As for Windows on an original Xbox. I’m sure I read once that proper drivers wouldn’t exist. Because nobody would have written them. Certainly Microsoft didn’t want you putting Windows on your Xbox. However I just came across this video of someone allegedly running Windows 98 on an Xbox. I’m not sure if they’re somehow virtualising Windows using Linux or something. Maybe have a look and figure out what’s going on: https://www.youtube.com/watch?v=erk_XE-D...
But Linux on an Xbox does look possible, IF you have a modded Xbox.
D C -
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
The repairability score varies on the model...
