Introdução
This guide can be used to fix the first generation of Xbox. When taking the Xbox apart to replace the fan make sure to be careful in carefully following all of the steps to ensure that you can put it back together properly.
O que você precisa
Vídeo de Apresentação
Turn the Xbox on its back and remove the rubber feet in each corner using a flathead screwdriver.
4 outras pessoas executaram este guia.
