Ir para o conteúdo principal
Xbox Elite Wireless Controller Series 2 Top Housing Replacement
O que você precisa
  1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: passo 1, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: passo 1, imagem 2 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: passo 1, imagem 3 %32
    • Use your fingers to remove the thumbstick toppers.
  2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: passo 2, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: passo 2, imagem 2 %32
    • Use your fingers to remove the D-pad cover.
  3. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: passo 3, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: passo 3, imagem 2 %32
    • The top housing is secured in two ways:
    • 13 tight plastic clips
    • Several strips of adhesive tape
  4. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: passo 4, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: passo 4, imagem 2 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: passo 4, imagem 3 %32
    • Releasing the plastic clips requires significant force. Take your time to avoid damaging your controller.
    • Insert an opening tool between the left bumper and the top housing.
    • Pry up the top housing to release the top left clip.
  5. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 5, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 5, imagem 2 %32
    • Insert an opening tool into the seam between the two housings on the controller’s left edge.
  6. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 6, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 6, imagem 2 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 6, imagem 3 %32
    • Slide the opening tool along the left edge and pry up intermittently to release the plastic clips.
  7. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 7, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 7, imagem 2 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 7, imagem 3 %32
    • Insert your opening tool into the seam between the two housings on the inner left edge.
    • Slide the opening tool along the bottom edge and pry up intermittently to release the plastic clips.
  8. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 8, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 8, imagem 2 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 8, imagem 3 %32
    • Insert your opening tool into the seam between the two housings on the controller’s right edge.
    • Slide the opening tool along the right edge and pry up intermittently to release the plastic clips.
  9. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 9, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: passo 9, imagem 2 %32
    • Insert your opening tool between the right bumper and the top housing.
    • Pry up the top housing to release the remaining plastic clips.
  10. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: passo 10, imagem 1 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: passo 10, imagem 2 %32 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: passo 10, imagem 3 %32
    • Remove the top housing.
    • To reinstall the top housing, position it on the midframe assembly and press down firmly along the edges to engage all of the clips.
Conclusão
19 outras pessoas executaram este guia.
Manuel Haeussermann
Membro desde: 07/13/22
22.738 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.623 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 18
Últimos 7 dias: 110
Últimos 30 dias: 409
Ao todo: 16,381
