Ir para o conteúdo principal
Xbox Disassembly
O que você precisa
Vídeo de Apresentação
  1. Xbox Disassembly, Xbox Disassembly: passo 1, imagem 1 %32
    • Start with your Xbox unplugged and sitting on a flat, stable surface.
  2. Xbox Disassembly: passo 2, imagem 1 %32
    • Flip the Xbox over and pry off the rubber feet with a metal spudger.
  3. Xbox Disassembly: passo 3, imagem 1 %32 Xbox Disassembly: passo 3, imagem 2 %32
    • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
    Or use an exacto knife to cut circles out where the two screws are located. First make indentations over the screws with your finger, this to help make it easier to trace the holes before cutting. The end result is often better than trying to peel corners. You can also try removing the stickers using a hair dryer, but it's not easy; if successful, they can potentially be reapplied, however.
    Nathan - Responder
  4. Xbox Disassembly: passo 4, imagem 1 %32
    • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
  5. Xbox Disassembly: passo 5, imagem 1 %32 Xbox Disassembly: passo 5, imagem 2 %32
    • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
  6. Xbox Disassembly: passo 6, imagem 1 %32 Xbox Disassembly: passo 6, imagem 2 %32
    • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Disassembly: passo 7, imagem 1 %32 Xbox Disassembly: passo 7, imagem 2 %32
    • Lift the hard drive storage unit out of the Xbox. It should come right out.
    • Take the power cable out of the track around the hard drive so that the unit will come out easier.
  8. Xbox Disassembly: passo 8, imagem 1 %32 Xbox Disassembly: passo 8, imagem 2 %32 Xbox Disassembly: passo 8, imagem 3 %32
    • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
    • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
  9. Xbox Disassembly: passo 9, imagem 1 %32 Xbox Disassembly: passo 9, imagem 2 %32
    • Unplug both the ribbon cable and power cable from hard drive.
    • They are in there pretty tightly, so this may take some effort.
    how do i do the wires
    elijah ross - Responder
    that was very hard
  10. Xbox Disassembly: passo 10, imagem 1 %32 Xbox Disassembly: passo 10, imagem 2 %32 Xbox Disassembly: passo 10, imagem 3 %32
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
    It was really challenging. Drive Mad
    chipmunkcot - Responder
  11. Xbox Disassembly: passo 11, imagem 1 %32
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
  12. Xbox Disassembly: passo 12, imagem 1 %32
    • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
  13. Xbox Disassembly: passo 13, imagem 1 %32 Xbox Disassembly: passo 13, imagem 2 %32
    • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
  14. Xbox Disassembly: passo 14, imagem 1 %32 Xbox Disassembly: passo 14, imagem 2 %32
    • Remove the power supply and set it aside. It should lift right out.
  15. Xbox Disassembly: passo 15, imagem 1 %32 Xbox Disassembly: passo 15, imagem 2 %32
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  16. Xbox Disassembly: passo 16, imagem 1 %32 Xbox Disassembly: passo 16, imagem 2 %32
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  17. Xbox Disassembly: passo 17, imagem 1 %32
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
  18. Xbox Disassembly: passo 18, imagem 1 %32
    • Pry the plastic fan clips away from the fan base and remove the fan.
    • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
  19. Xbox Disassembly: passo 19, imagem 1 %32 Xbox Disassembly: passo 19, imagem 2 %32
    • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
    • Take the sockets out by pulling back and up at the same time.
  20. Xbox Disassembly: passo 20, imagem 1 %32
    • Congratulations, your Xbox is now completely dismembered.
    Thanks made my day i shall put it in a old radio =) Perra
    Perra - Responder
    My Xbox is not completely disassembled. How do I get the front panel and metal shield out of the bottom case so I can wash them?
    Michael J Cotton - Responder
    Same here. I got everything out but the front. Trying to replace the power/eject button
    Joshua Sweeney -
    You forgot the power button area....
    Christopher Mee - Responder
Conclusão
48 outras pessoas executaram este guia.
rmarstel
Membro desde: 10/29/09
5.674 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 18-2, Maness Fall 2009 Membro de Cal Poly, Team 18-2, Maness Fall 2009
CPSU-MANESS-F09S18G2
Membros da 3
Autoria de 24 guias
10 comentários
Awesomeness, thanks a lot!
godoyander - Responder
Thanks a million - perfect!
xan_lucky16 - Responder
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - Responder
would you be able to make a guide on how to remove the plastic outer shell from the metal parts inside? i want to clean a dirty shell but i don't know how to get the parts seperated.
Davis Williams - Responder
Looks like I'm not skilled at fixing things, my machine broke right after that.
stickman fighter
LouisPaul - Responder
Attractive information. I can fix the Xbox. Your steps are excellent. Have a nice day, bro!
baldi's basics
Walt Junc - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 70
Últimos 7 dias: 450
Últimos 30 dias: 1,908
Duração total: 181,310
