Pular para o conteúdo principal
Introdução
If the controller stops vibrating, the rumble motors might be broken or disconnected. This guide will show you how to open the controller and replace the rumble motors.
  1. Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller. Pull the two AA batteries out.
    • Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
    • Pull the two AA batteries out.
  2. Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw. Use a T6 Torx screwdriver to remove the 1.5mm screw.
    • Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
    • Use a T6 Torx screwdriver to remove the 1.5mm screw.
  3. Insert a spudger and pry at these three locations to detach the middle cover. Pull off the middle piece cover to reveal three screws. Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Insert a spudger and pry at these three locations to detach the middle cover.
    • Pull off the middle piece cover to reveal three screws.
    • Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Remove the cover.
  4. Remove the two 90mm screws with a T8 Torx screwdriver. Lift up the silver middle piece to remove. Lift up the silver middle piece to remove.
    • Remove the two 90mm screws with a T8 Torx screwdriver.
    • Lift up the silver middle piece to remove.
  5. Use a spudger to remove the silver prong. With the spudger, pinch the metal spring and slowly pull up to remove. Use the spudger to remove eject button.
    • Use a spudger to remove the silver prong.
    • With the spudger, pinch the metal spring and slowly pull up to remove.
    • Use the spudger to remove eject button.
    • Remove the screw holding in the eject button with a T8 Torx screwdriver.
  6. This step is very difficult and may require a third hand. Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together. Start with one side of the controller (left or right).
    • This step is very difficult and may require a third hand.
    • Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
    • Start with one side of the controller (left or right).
    • Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
    • The white circular caps at the top of the controller will pop off by applying light force.
    • Pull the front and back panels apart to separate them and expose the inside of the controller.
  7. Lift the battery compartment out of the controller and set it outside of the controller. Do not yank, stress, or pull on the wires for removal. Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
    • Lift the battery compartment out of the controller and set it outside of the controller.
    • Do not yank, stress, or pull on the wires for removal.
    • Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
  8. Use precision tweezers to remove the red and black wires that are attached to the circuit board. The rumble motors will easily  lift out of the controller once the wires are detached.
    • Use precision tweezers to remove the red and black wires that are attached to the circuit board.
    • The rumble motors will easily lift out of the controller once the wires are detached.
Conclusão
Mateo
Membro desde: 15-02-2018
73 reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S16-G5, Boczar Spring 2018 Membro de USF Tampa, Team S16-G5, Boczar Spring 2018
USFT-BOCZAR-S18S16G5
5 Membros
8 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Todo: 148
