Introdução
Make your Xbox 360 S look shiny and new by replacing the outer panels.
O que você precisa
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
Pull the hard drive straight out of the console.
If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
You will still have your saves and account if you replace your hard drive in the new xbox
hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
These are pretty awkward to remove, but once you understand how they work its easy enough. The goal here is to slot the spudger THROUGH the gap of the silver tabs (visible in previous steps image, circled) and then pry. Put pressure against the wall of the Xbox case and push downwards, once you feel the spudger slot in, then apply force away from the Xbox and pull up a little with your free hand.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
This step is and the others following are to rough and not needed, simply put smth in between the lamellar and push it up with littlebit pressure thats better for the plastic parts.
Insert a metal spudger between the fan vent and top bezel along the left side of the console.
In the same manner described above, begin prying the left side of the top vent away from the top bezel.
Continue prying along the left side of the device, freeing all the clips on that side.
Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
So I got the fan filter thing off, but the black edge plate thing isn't coming off. All I did was warp my flathead screwdriver and scratch the console.
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
Rotate the spudger upward to release the last clip.
if you make a hole right here like the link`s picture you can boot the lock
As the user above me said, please avoid doing it like shown in the guide. It just didn’t work on my Xbox (unless your goal is to destroy the plastic case). Instead, pick some small needle like object (the spudger was too short for this, I used the SIM bit of my iFixit driver kit) and find the right spot on the big sticker which is on the left in the pictures shown in the guide. That spot is just between the text and the column of logos (Dolby Digital, etc.) (https://team-xecuter.com/slim/slim_secre..., picture not mine). Poke it (don’t be too gentle, you have to apply some force) and you will hear the clip release.
Both the above links are dead, i used this YouTube video which shows you the process of getting the hidden clip
I was able to open it by pushing on the sticker to unclamp the clip while another person helped me pull open the case.
Here is a Video that shows the small hole behind the sticker, ist in german but ist good to see how to open that hidden clip easiely.
26 outras pessoas executaram este guia.
2 comentários
Prying the top and bottom case apart with a metal spudger?, you'll ruin your xbox 360 slim case....your already voiding your warrenty, why not open it the right way??, their's is a pin-hole located at the back where the sticker is, just stick a pin into it and it will release that clip thats holding it together!
if you are going to do something like open your xbox360, do it right the first time.......
ATTENTION: The metal spudger is absolutely wrong for that second tab, you will never reach it. Instead, place your thumb over where the security sticker is on the top half of the case and apply pressure, the tab will snap out of place with the right amount of gradual force. This drove me nuts for an hour and I found the solution elsewhere.
