Introdução
There is no such thing as too much hard drive space, and nothing more frustrating than too little. This guide will show you how to replace your Xbox 360 S hard drive.
O que você precisa
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
103 outras pessoas executaram este guia.
5Comentários do guia
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
no the os is on the internal drive all the hard drive is doing is adding more storge space
My hardrive says its unformated but its not and i dont want to loose content
Can I take the external out of the little black cover?
Will it play backwards compatible games
