Ir para o conteúdo principal
Xbox 360 Hard Drive Replacement
O que você precisa
  1. Xbox 360 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Xbox 360 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    WARNING: Just replacing the drive will not make it work correctly. Microsoft has married the drives to the motherboard. Hence, in order to get full operation out of the drive you'll have to perform more steps not listed here. Search in the FAQ on this specific topic for more details. Otherwise, before buying a new drive, try cleaning the inside of the old one and/or replace the belt involved in opening and closing the drive door.
    - Good Luck
    Eric - Responder
    bress the button and lift with the same hand! i thought mine was stuck because of this pic!!!
    Maths with Luigi - Responder
Conclusão
66 outras pessoas executaram este guia.
2 comentários
that was very difficult
Michael Drawdy - Responder
that was so hard i dropped my xbox and not it has the red ring of death
Nednal404 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 31
Últimos 30 dias: 118
Duração total: 25,461
