Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Here it is. The standard 20GB HDD for the Xbox 360.
Notice the proprietary adapter. Inside is just a pretty standard 2.5" SATA drive...
I took these pictures as I was putting it back together, hence the Microsoft warranty sticker looking a little funny.
It only voids the warranty for the drive, not the console, being as their warranties are separate.
Proceed to remove the four T6 Torx screws.
Holding the drive top up, gently pull the top half up from the bottom half. The back will rotate up as the front is connected by two plastic clips.
These clips are most easily undone by rotating the top enclosure to about 30º then lifting it up firmly.
Remove the four T10 Torx screws.
Slide the cover towards the back of the enclosure and remove. There is a small dot of lock-tite on each screw, fyi.
Here are the innards in all their glory.
The four screws that held the cover on also held the drive in place, so just pull off the SATA connector and the drive is almost free.
To actually get the drive out, you must bend the back of the plastic part of the bottom enclosure down a little bit. Doing so shouldn't break anything, just don't go overboard and bend it excessively.
All the parts disassembled. The adapter cable will probably come out as it doesn't seem to be attached directly, but removing it would have required bending the metal enclosure and I didn't want to mess with that.
I thought it interesting to note that the drive runs at 5V 0.62A when the enclosure states 5V 1A. I wonder where the other 380mA are going.
Also interesting to note: this is a Seagate drive, while the 250GB drive upgrade I mention in the description requires a WD drive. If I understood correctly, this is because the software to format the drive to be recognized by your 360 is written for the WD firmware.
66 outras pessoas executaram este guia.
3 comentários
I happen to have an external HD enclosure (the original HD had a platter crash) that works perfectly to mount the XBox 360 HD to my PC for all sorts of uses, allowing for either USB or external SATA connectivity. :D
Link to article seems to be down. Any mirrors? It woulb be much appreciated, Thanks
Sounds and looks easy enough. But will replacing a 20 go drive with a 250 go drive now need any formatting or can I just plug it in and work?
