Introdução
When you can't download the game you just have to have follow this guide to replace your Wi-Fi card.
O que você precisa
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
Firmly grip the green Wi-Fi card and pull it out of the Xbox.
On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
5 outras pessoas executaram este guia.
