Ir para o conteúdo principal
Xbox 360 E Motherboard Replacement
O que você precisa
  1. Xbox 360 E Motherboard Replacement, Top Panel: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $2.99
    Comprar
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E Motherboard Replacement: passo 2, imagem 1 %32
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E Motherboard Replacement: passo 3, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 3, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 3, imagem 3 %32
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E Motherboard Replacement, Bottom Panel: passo 4, imagem 1 %32
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  5. Xbox 360 E Motherboard Replacement: passo 5, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 5, imagem 2 %32
    • Slide the spudger along the crevice to separate the grated face and the top body.
  6. Xbox 360 E Motherboard Replacement: passo 6, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 6, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 6, imagem 3 %32
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  7. Xbox 360 E Motherboard Replacement, Front Panel: passo 7, imagem 1 %32 Xbox 360 E Motherboard Replacement, Front Panel: passo 7, imagem 2 %32 Xbox 360 E Motherboard Replacement, Front Panel: passo 7, imagem 3 %32
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
  8. Xbox 360 E Motherboard Replacement: passo 8, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 8, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 8, imagem 3 %32
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  9. Xbox 360 E Motherboard Replacement: passo 9, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 9, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 9, imagem 3 %32
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    My actual disk tray came off the track looking into the best way to repair it
    David Mitchell - Responder
  10. Xbox 360 E Motherboard Replacement: passo 10, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 10, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 10, imagem 3 %32
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  11. Xbox 360 E Motherboard Replacement: passo 11, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 11, imagem 2 %32
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  12. Xbox 360 E Motherboard Replacement: passo 12, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 12, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 12, imagem 3 %32
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
  13. Xbox 360 E Motherboard Replacement, RF Module: passo 13, imagem 1 %32 Xbox 360 E Motherboard Replacement, RF Module: passo 13, imagem 2 %32 Xbox 360 E Motherboard Replacement, RF Module: passo 13, imagem 3 %32
    • Looking at the body of the device, locate the green panel to the right of the CD drive.
    • Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
    • Grip the middle of the green board and gently pull it out.
  14. Xbox 360 E Motherboard Replacement, Wi-Fi Card: passo 14, imagem 1 %32
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    In my case it was a T10 Screw, not T9
    Limer o - Responder
  15. Xbox 360 E Motherboard Replacement: passo 15, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 15, imagem 2 %32
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
    Tyler Goyette - Responder
  16. Xbox 360 E Motherboard Replacement, Bottom Body: passo 16, imagem 1 %32 Xbox 360 E Motherboard Replacement, Bottom Body: passo 16, imagem 2 %32 Xbox 360 E Motherboard Replacement, Bottom Body: passo 16, imagem 3 %32
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
  17. Xbox 360 E Motherboard Replacement: passo 17, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 17, imagem 2 %32
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
  18. Xbox 360 E Motherboard Replacement: passo 18, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 18, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 18, imagem 3 %32
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
  19. Xbox 360 E Motherboard Replacement: passo 19, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 19, imagem 2 %32
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
  20. Xbox 360 E Motherboard Replacement, Top Body: passo 20, imagem 1 %32 Xbox 360 E Motherboard Replacement, Top Body: passo 20, imagem 2 %32
    • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
    • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
    And not T9 - the're T10 screws
    Limer o - Responder
    Missing some steps here…. Where are the clips holding the sides together? To go straight from “Remove bottom cover” to “Device is apart” is a bit… lacking.
    Aksel Barnes - Responder
    Yes, Aksel Barnes is correct. There are missing pictures and steps showing the removal of the plastic exterior from the metal section.
    yovel binjamin - Responder
    another "manual" missing the hardest steps
    Thijs van Ulden - Responder
    Just wanted to share my experience: after you "spudge" off the top and bottom you have to "spudge" off the front as well. Then you can follow the rest of the steps
    lilmolens - Responder
  21. Xbox 360 E Motherboard Replacement, CD Drive: passo 21, imagem 1 %32 Xbox 360 E Motherboard Replacement, CD Drive: passo 21, imagem 2 %32
    • Use your fingers to unplug the blue ribbon cable from the CD drive.
    Note: The ribbon cable connected to the CD drive can be in the color red (as it was on my board). Just make sure the other end is connected to the motherboard to be sure.
  22. Xbox 360 E Motherboard Replacement: passo 22, imagem 1 %32
    • Use tweezers to unplug the blue and pink wires.
  23. Xbox 360 E Motherboard Replacement: passo 23, imagem 1 %32
    • Lift the front end of the CD drive and take it out.
    Just note that you will have to swap the PCB inside the disc drive. If you do not go through with this the game will not start.
    You do also require some soldering skills as the wires for the motor and sensor for the disc tray are soldered to the PSB.
    Michael Mouton - Responder
  24. Xbox 360 E Motherboard Replacement, Motherboard: passo 24, imagem 1 %32 Xbox 360 E Motherboard Replacement, Motherboard: passo 24, imagem 2 %32
    • From the bottom of your Xbox, take your T9 torx screwdriver and take out all of the 11 mm screws labelled B1-7
    • Don't forget a screw on the side of the Xbox next to the power plug.
    They’re actually T10
    Felipe Martinez - Responder
    The screw B1 is not shown it is written on the board and is located at the bottom right of the picture. The red circle mark doesn't show a screw.
  25. Xbox 360 E Motherboard Replacement: passo 25, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 25, imagem 2 %32
    • Flip the Xbox over and take out the heat sink plastic shield.
  26. Xbox 360 E Motherboard Replacement: passo 26, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 26, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 26, imagem 3 %32
    • Unplug the red cable.
    • Unplug the blue cable.
    • Take the hard drive assembly by the long plastic arm and lift the entire thing out.
  27. Xbox 360 E Motherboard Replacement: passo 27, imagem 1 %32
    • Flip the Xbox to the back and take your T10 torx screwdriver and take out the last four 6 mm screws labelled A1-4.
  28. Xbox 360 E Motherboard Replacement: passo 28, imagem 1 %32 Xbox 360 E Motherboard Replacement: passo 28, imagem 2 %32 Xbox 360 E Motherboard Replacement: passo 28, imagem 3 %32
    • Back to the top of the Xbox, take out the metal and plastic insert.
    • Place two fingers in between the grooves in the metal body and the motherboard and pull up slightly. Do not pull up from the side with the plugs like the HDMI and internet.
    • As the motherboard comes up, switch to the left side and continue pulling the motherboard up.
    • Once that side of the motherboard is out, lift the rest of the motherboard away from the metal body.
Conclusão
36 outras pessoas executaram este guia.
Bryce
Membro desde: 01/31/14
1.331 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-11, Amido Winter 2014 Membro de Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
Membros da 4
Autoria de 43 guias
4 comentários
Where can I get the motherboard?
Derek Bullard - Responder
Need a motherboard.....
supergametime - Responder
How did you go finding one ? , I gotta get one I think , any chance u could get hold of me by email or I'm on fb ? , just wanna ask you about something with xbox memory n error cap
Daniel Leach -
Would have been nice to include the heatsink removal procedure even if it is similar to the original 360. Also I have never had extra screws left over, yet I have 2 phillips screws left over which are mentioned nowhere in this guide. From no point of the teardown process could I find where they came from.
dot s - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 45
Últimos 30 dias: 248
Duração total: 26,222
