Introdução
Verwende diesen Guide um den Lüfter an der Unterseite deiner Xbox 360 auszutauschen.
O que você precisa
Ferramenta utilizada nesse passo:Xbox 360 Opening Tool$4.99
Führe das flache Ende eines Spudgers oder die Kante eines Xbox 360 opening tools in den kleinen Schlitz an der Seite des Front Pannels in der Unterseite.
Hebel die vordere Kante des Lüfters weg von der Frontplatte.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
68 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Theo Mat está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
You can avoid this step by pulling the front cover off. Just make sure you don't break the springs for the USB bay area.
Repair Doctor - Responder
Hello, thank you ifix for this guide, I followed this guide, I got stuck at some point but I resolved it. Also I want to share this resource: Step by Step guide to fix Xbox 360 errors it helped me go through all the things associated with Xbox 360 and the troubleshooting of errors. Hope this can also help you all.
Christopher Sage - Responder
