Ir para o conteúdo principal
X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement
O que você precisa
  1. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 2, imagem 1 %32
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Underbody: passo 3, imagem 1 %32
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 4, imagem 1 %32
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 5, imagem 1 %32 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 5, imagem 2 %32
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 6, imagem 1 %32
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 7, imagem 1 %32
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 8, imagem 1 %32 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 8, imagem 2 %32
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 9, imagem 1 %32 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 9, imagem 2 %32
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 10, imagem 1 %32
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 11, imagem 1 %32
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: passo 12, imagem 1 %32 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: passo 12, imagem 2 %32 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: passo 12, imagem 3 %32
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column Spring: passo 13, imagem 1 %32
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 14, imagem 1 %32
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: passo 15, imagem 1 %32
    • Carefully remove the steering column spring.
Conclusão
Uma outra pessoa concluiu este guia.
Liam Martinez
Membro desde: 04/01/15
562 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-3, Lancaster Spring 2015 Membro de Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 273
