Ir para o conteúdo principal
X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement
O que você precisa
  1. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 2, imagem 1 %32
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement, Underbody: passo 3, imagem 1 %32
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 5, imagem 1 %32 X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 5, imagem 2 %32
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 6, imagem 1 %32
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 7, imagem 1 %32
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 8, imagem 1 %32 X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 8, imagem 2 %32
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 9, imagem 1 %32 X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 9, imagem 2 %32
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 11, imagem 1 %32
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Desolder all wires connected to the motherboard.
    • In this step, you will have to take great care in keeping track of the wires
    • Our suggestion is to attach tape to each wire, and letter the tape. Letter each tape according to the respective lettering found on the motherboard.
  13. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: passo 13, imagem 1 %32
    • Unscrew the two 1.6mm Phillips #000 screws connecting the motherboard to the under body of the car.
Conclusão
Alex Borsotti
Membro desde: 04/01/15
136 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-3, Lancaster Spring 2015 Membro de Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
Membros da 3
Autoria de 9 guias
2 comentários
Hello I need to buy new circuit, can u guide me to any webstore? Thanx
mmekawtar - Responder
Where can I by a replacement circuit board? PLease.
Joe Welsh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 559
