Ir para o conteúdo principal
X-Treme Tablet Generation 2 Speaker Replacement
O que você precisa
  1. X-Treme Tablet Generation 2 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Using a spudger and pry tool, remove the back cover. Start at the top corner, and carefully pry the back cover off of the main body.
    • Continue around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Speaker Replacement: passo 2, imagem 1 %32 X-Treme Tablet Generation 2 Speaker Replacement: passo 2, imagem 2 %32
    • Using a solder vacuum and soldering iron, release the red wire from the motherboard first, then release the black wire.
    • The speaker is held on the back cover with adhesive tape. Using a pry tool, carefully pry the speaker from the back cover.
Conclusão
Kristen John
Membro desde: 01/26/15
125 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 378
