Ir para o conteúdo principal
X-Treme Tablet Generation 2 Motherboard Replacement
O que você precisa
  1. X-Treme Tablet Generation 2 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the cover from the back of the tablet. Using the pick tool, pry the cover the case. Do this by starting in the upper corner, working around the edges until the cover unclips from the case.
  2. X-Treme Tablet Generation 2 Motherboard Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • Find and detach all of the connections to the motherboard. Remove the connections while leaving the components in place from the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Remove the connections using a soldering iron and desolder pump to remove the current soldered connections.
  3. X-Treme Tablet Generation 2 Motherboard Replacement: passo 3, imagem 1 %32 X-Treme Tablet Generation 2 Motherboard Replacement: passo 3, imagem 2 %32
    • Replacing the defective motherboard with a functional motherboard: Reattach the connections at the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Reattach the connections by soldering them back onto the motherboard using a soldering iron.
Conclusão
Dalton Croslow
Membro desde: 11/10/18
97 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G3, Wilson Fall 2018 Membro de IUPUI, Team S3-G3, Wilson Fall 2018
IUPUI-WILSON-F18S3G3
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 206
