O que você precisa
If your Colormunki is behaving eratically while trying to select the calibrating position you may have either one, or both of the following issues. The flat cable within the housing is broken. The light reflecting patches within the housing need refurbishing.
4 outras pessoas concluíram este guia.
2 comentários
I only had to replace the reflectors, used some chrome tape from Michaels.
Would it be possible to disconnect or even remove the status LED? Would the colormunki then still work? Thanks in advance for your answers.
