Ir para o conteúdo principal
Wyze WVCR200s Rotating Brush Replacement
  1. Wyze WVCR200s Rotating Brush Replacement, Rotating Brush: passo 1, imagem 1 %32
    • Flip the vacuum upside down so the bottom is facing up.
    • In the center of the device, you should see the rotating brush that stretches from one wheel to the other.
  2. Wyze WVCR200s Rotating Brush Replacement: passo 2, imagem 1 %32 Wyze WVCR200s Rotating Brush Replacement: passo 2, imagem 2 %32
    • Pinch the blue tabs below the rotating brush towards each other.
    • Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
  3. Wyze WVCR200s Rotating Brush Replacement: passo 3, imagem 1 %32 Wyze WVCR200s Rotating Brush Replacement: passo 3, imagem 2 %32 Wyze WVCR200s Rotating Brush Replacement: passo 3, imagem 3 %32
    • To remove the rotating brush, lift one end of the brush upwards, and remove.
Conclusão
Brendan
Membro desde: 03/20/23
181 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Membro de UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 179
