Introdução
The Wyze Cam V2 comes with a electret condenser microphone that allows you to converse with people on the other side of the device. If your microphone becomes faulty it makes it hard to have conversations so you might need to get it replaced and this guide will walk you through the steps in doing that.
O que você precisa
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
Carefully remove the motherboard from the device.
