Ir para o conteúdo principal
Wrought Iron Security Door Handle Replacement
O que você precisa
Vídeo de Apresentação
  1. Wrought Iron Security Door Handle Replacement, Wrought Iron Security Door Handle: passo 1, imagem 1 %32 Wrought Iron Security Door Handle Replacement, Wrought Iron Security Door Handle: passo 1, imagem 2 %32 Wrought Iron Security Door Handle Replacement, Wrought Iron Security Door Handle: passo 1, imagem 3 %32
    • First, open and then position the door to a desired width.
    • Secure the door by using the sliding latch of the cylinder or door prop.
    • This will enable the door to stay open while replacing the handle.
    • Use a screwdriver to begin removing the screws from the handle.
    • The type of screwdriver to use will depend on the type of screws. A Philip screwdriver is being used to remove the screws from the security door.
  2. Wrought Iron Security Door Handle Replacement: passo 2, imagem 1 %32 Wrought Iron Security Door Handle Replacement: passo 2, imagem 2 %32 Wrought Iron Security Door Handle Replacement: passo 2, imagem 3 %32
    • Carefully begin to disassemble all parts of the handle by removing the handle from the door.
    • It may be easier to begin removing the exterior handle first while removing the screws from the interior handle.
    • Continue to disassemble the interior handle by removing the top and bottom screws.
  3. Wrought Iron Security Door Handle Replacement: passo 3, imagem 1 %32 Wrought Iron Security Door Handle Replacement: passo 3, imagem 2 %32
    • Once the handle is disassembled, make sure all of the parts from the handle that is being replaced are free of any type of debris, remaining parts, etc.
  4. Wrought Iron Security Door Handle Replacement: passo 4, imagem 1 %32 Wrought Iron Security Door Handle Replacement: passo 4, imagem 2 %32 Wrought Iron Security Door Handle Replacement: passo 4, imagem 3 %32
    • When installing the new handle to the wrought iron security door, begin by inserting the lock shaft in the middle of the exterior handle.
    • Insert the lock shaft, along with the exterior handle, through the center hole of the door to where the handle is being replaced.
  5. Wrought Iron Security Door Handle Replacement: passo 5, imagem 1 %32 Wrought Iron Security Door Handle Replacement: passo 5, imagem 2 %32 Wrought Iron Security Door Handle Replacement: passo 5, imagem 3 %32
    • Once the exterior handle is installed along with the lock shaft, align the new handle according to where the current holes are positioned.
    • Insert or thread the top and bottom screws by hand into the interior handle.
    • While holding the exterior handle in place, carefully insert the interior door handle along with the screws to connect with the exterior handle.
  6. Wrought Iron Security Door Handle Replacement: passo 6, imagem 1 %32 Wrought Iron Security Door Handle Replacement: passo 6, imagem 2 %32
    • Once both handles and screws are inserted and in place, by holding the exterior handle, use the Philip screwdriver to finish installing the screws.
    • It may be easier to hold the exterior door handle in place while installing the screws.
  7. Wrought Iron Security Door Handle Replacement: passo 7, imagem 1 %32 Wrought Iron Security Door Handle Replacement: passo 7, imagem 2 %32
    • After completing the installation of the screws to the handle, make sure that all parts of the handle are functioning properly and securely.
Conclusão
To reassemble the handle, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Marsha Hill
Membro desde: 06/09/23
175 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 802
