Introdução
This guide shows you which screws and which pieces to remove in order to access the wheel housing.
O que você precisa
Remove the 1.2 mm Phillips screws surrounding the wheel and take off the wheel cover.
Uma outra pessoa concluiu este guia.
Um comentário
This will require a TON of pressure on the screw. I tried it. The wheel is removable even without taking out the screw, since it does not require much force this way, either.
